The following SQL and Table API features are supported in Cloudera Streaming Analytics.
StreamTableEnvironment (Blink Planner) |
Catalogs |
- DataStream conversions:
- Temporary views
- SQL update and Query operations
- Creating and using catalogs
- Listing catalogs, tables, databases and functions
- In-memory - Flink default catalog
- Hive
- Schema Registry
- Kudu
SQL update statements |
SQL query statements |
CREATE TABLE
- Computed columns
- Watermark definitions
- Table connectors
- Kafka
- Kudu
- Hive (through catalog)
- Data formats (Kafka)
INSERT INTO
- Basic operations
- Basic aggregations
- Group By
- Group By Window
- Distinct (only windowed)
- Joins
- Time-windowed stream-stream join
- User defined scalar functions (scalar udf)
