SQL jobs Creating and naming SQL jobsYou need to create or select an already existing SQL job on the Streaming SQL Console to be able to submit SQL queries.Running SQL Stream jobsEvery time you run an SQL statement in the SQL Stream console, it becomes a job and runs on the deployment as a Flink job. You can manage the running jobs using the Jobs tab on the UI.Configuring SQL job settingsIf you need to further customize your SQL Stream job, you can add more advanced features to configure the job restarting method and time, threads for parallelism, sample behavior, exactly once processing and restoring from savepoint.Configuring state backend for Cloudera SQL Stream BuilderThe same state backend configuration is applied to the SQL jobs in Cloudera SQL Stream Builder as configured for the Flink jobs. While Hashmap stores data as object on Java heap, RocksDB can be used to store larger state that does not fit easily in memory. The RocksDB state backend uses a combination of fast in-memory cache and optimized disk based lookups to manage state.Managing session for SQL jobsBy default, the SQL Stream jobs are running in a session cluster. This means that multiple Flink jobs run in the same YARN session sharing the cluster, allocated resources, the Job Manager and Task Managers. The session starts when you open the Streaming SQL Console. You can reset the session, and set the properties of the session using the Streaming SQL Console.
