Setting up PostgreSQL database for Cloudera SQL Stream Builder
After installing PostgreSQL server, you must rename the JDBC connector, and create a database with credentials for Cloudera SQL Stream Builder before installing the service on your cluster. You also must install the PostgreSQL Python connector to integrate with the Streaming SQL Engine.
Before you begin
You need to install and configure PostgreSQL, before setting up the databases for Cloudera SQL Stream Builder. To install and configure PostgreSQL, you must complete the basic steps mentioned in the Cloudera Private Cloud Base documentation.
Installing the PostgreSQL JDBC connector
- Download the PostgreSQL JDBC Driver from the PostgreSQL website.
- Rename the JDBC jar file to
postgresql-connector-java.jar.mv postgresql-jdbc.jar postgresql-connector-java.jar - Copy the PostgreSQL JDBC jar file to your host.This host must be the same host where you plan to assign the Streaming SQL Engine service role. The service roles are assigned as a next step when installing Cloudera SQL Stream Builder as a service in Cloudera Manager.
You will be prompted to provide your password.scp <location>/postgresql-connector-java.jar root@<your_hostname>: - Access the host on your cluster.This host must be the same host where you have added the JDBC jar file.
You will be prompted to provide your password.ssh root@<your_hostname> - Copy the PostgreSQL JDBC jar file to
/usr/share/javafolder using the following command:sudo mkdir -p /usr/share/java sudo cp <location>/postgresql-connector-java.jar /usr/share/java - Check if the PostgreSQL connector is in the folder with
lscommand.
Creating PostgreSQL database for Cloudera SQL Stream Builder
- Access a host on your cluster.This host must be the same host where you plan to assign the Materialized Views Engine and Streaming SQL Engine service role. The service roles are assigned as a next step when installing Cloudera SQL Stream Builder as a service in Cloudera Manager.
You will be prompted to provide your password.ssh root@<your_hostname> - Connect to PostgreSQL:
sudo -u postgres psql - Create a database for the Cloudera SQL Stream Builder
metadata:
CREATE ROLE ssb_admin LOGIN PASSWORD '<password>'; CREATE DATABASE ssb_admin OWNER ssb_admin ENCODING 'UTF8'; - Create a database for the Materialized View
Engine:
CREATE ROLE ssb_mve LOGIN PASSWORD '<password>'; CREATE DATABASE ssb_mve OWNER ssb_mve ENCODING 'UTF8'; - Confirm that you have created the Streaming SQL Engine and Materialized View
Engine database using the
\lcommand.
