In this example, you will use the Stateless Monitoring Application from the Flink
  Tutorials to build your Flink project, submit a Flink job and monitor your Flink application using
  the Flink Dashboard in an unsecured environment.
    Clone the simple tutorial from git:
     git clone https://github.com/cloudera/flink-tutorials.git
    Access the simple tutorial folder:
     cd flink-tutorials/flink-simple-tutorial
    Build your Flink project using maven:
    Upload the Flink project to your cluster.
     scp <location>/flink-stateful-tutorial-1.2-SNAPSHOT.jar root@<your_hostname>:.
    Run the Flink application:
     flink run -d -p 2 -ynm HeapMonitor target/flink-simple-tutorial-1.2-SNAPSHOT.jar
    Navigate to , and select the environment where you have created your cluster.
    Select the Cloudera Streaming Analytics cluster.
    Click Flink Dashboard from the services.
The Flink Dashboard opens in a new window.
    Click Task Manager on the left side menu.
    Monitor your Flink application under logs.
