SSB metadata collection using Atlas
As Cloudera SQL Stream Builder is built on Flink, you can use the Apache Atlas and Flink integration, and collect the metadata of your Flink jobs submitted from it. Using Atlas, you can find, organize and manage different assets of data about your Flink applications and how they relate to each other.
To use Atlas with Cloudera SQL Stream Builder, you need to create entity type definitions for Flink in Atlas, and enable the metadata collection in Cloudera Manager for Flink.
For more information, see the Flink metadata collection using Atlas .
