Adding Catalogs
You need to add Cloudera Schema Registry, Kudu, Hive, Confluent Schema Registry or other services as a Catalog using the Streaming SQL Console in Cloudera SQL Stream Builder to use them with Flink DDL.
- Make sure that you have the required service on your cluster.
 - Make sure that you have the right permissions set in Ranger for Cloudera SQL Stream Builder and the services.
          Open a project from the Projects page of Streaming SQL
            Console.
- Select an already existing project from the list by clicking the Open button or Switch button.
 - Create a new project by clicking the New Project button.
 - Import a project by clicking the Import button.
You are redirected to the Explorer view of the project. - Open Data Sources from the Explorer view.
                Click
 next to Catalogs.
                Select New Catalog.
                The Add Catalog window appears.
                Select the Catalog Type from the following
                    options:
- Add a Name to your catalog.
 - Select Schema Registry from the
                                        Catalog Type drop-down.
                                     - Select the Kafka cluster you registered as Data Source.
 - Enable TLS, if needed for the communication.
- If you enabled TLS, provide the Schema Registry Truststore location and password to the SR TrustStore and SR TrustStore Password field.
 - Add the Schema Registry URL.
 - Select Schema Registry from the list of services.
 - Click on Instances.
 - Copy the Hostname of Schema Registry.
 - Add the default port of Schema Registry after the
                                                hostname.Example:
http://docs-test-1.vpc.cloudera.com:7788/api/v1
 - Optional: Specify a Schema key suffix and
                                    a Schema value suffix.
By default, the Schema Registry catalog looks for a topic in Kafka with the same name as the schemas stored in Cloudera Schema Registry. It uses the schema to deserialize the payload of the messages in that topic and ignores the message key. If you have different schemas to deserialize message key and payload you can define suffixes to differentiate them.For example, if you configure the catalog's schema key suffix as
-keyand the schema value suffix as-value, and you have schemas stored in Cloudera Schema Registry namedexample-keyandexample-value. The Cloudera SQL Stream Builder catalog will automatically create a table calledexampleand use those schemas to deserialize the key and the payload of the messages, respectively. - Optional: Add a Prefix for key fields in
                                        schema.You can set a prefix for key field names to avoid table creation failure as the column names in the Flink schema are created based on the field names of the Avro schema. Table creation fails if the key and value schemas contain overlapping fields. The provided prefix will be assigned to the key fields of the Flink table as shown in the following example:
CREATE TABLE … (k_a INT, k_b INT, b INT, c INT0 with (..., ‘key.fields’=’k_a;k_b’)
- Select Kudu from the Catalog Type
                                        drop-down.
                                     - Add the host URL of Kudu Masters.
 - Select Kudu from the list of services.
 - Copy the Hostname of the Master Default Group.
 - Add the default port of Kudu after the
                                                hostname.Example:
docs-test-1.vpc.cloudera.com:7051
- Select Hive from the Catalog Type
                                        drop-down.
                                     - Provide a Name to the Hive catalog created in SSB.
 - Provide the name of the Default Database in Hive.
- Select Confluent Schema Registry from the
 - Add the Confluent Cloud Schema Registry URL provided by your Confluent connection configurations.
 - Choose an Authentication method from the following:
- BASIC
 - If the basic authentication method is selected, you must provide the username and password.
 - CUSTOM
 - Custom authentication methods include bearer
                                                  authentication, SSL authentication and so on. If
                                                  the custom authentication method is selected, you
                                                  must provide the authentication property keys to
                                                  the Custom Properties field
                                                  as they are set for the Confluent Cloud Schema
                                                  Registry. For example, if the Confluent Cloud
                                                  Schema Registry is configured with bearer
                                                  authentication, you need to provide the
bearer.auth.credentials.sourceandbearer.auth.token. If SSL authentication is configured, theschema.registry.ssl.keystore.location,schema.registry.ssl.keystore.passwordand so on must be provided.
- Select Custom from the Catalog Type
                                        drop-down.
                                     - Provide a Property Key.
 - Proivde a Property Value.
If needed, you can specify more custom properties by using the plus icon.
                Click on Add Filter.
- Provide a Database and Table filter if you want to select specific tables to use from the catalog.
 - Click on Validate.
 - If the validation is successful, click Create.
 - Click
 next to Catalogs. - Select Manage.
The Catalogs tab opens where the registered catalogs are listed. You have the following options to manage the catalog sources:
- Click on one of the existing catalogs to edit its configurations.
 - Click
 to remove the catalog. - Click
 to duplicate the catalog with
                            its configurations.
