Creating a project
Before you can use Streaming SQL Console, you need to create a project where you can submit your SQL jobs and manage your project resources.
  2. Click New Project on the Projects page of Streaming SQL Console.
    The Create Project window appears.
  3. Provide a Name to the project.
  4. Optional: Provide a Description to the project.
  5. Optional: Provide a prefix that overrides the Materialized View table names.
  6. Optional: Provide the Source Settings of the project.
    1. Add a remote Github repository URL to the Clone URL field.
      • To clone without authentication: https://github.com/cloudera/ssb-examples.git
      • To clone and push with HTTP basic authentication (username/password): https://github.com/cloudera/ssb-examples.git
        In case of using basic authentication, the personal access token needs to be provided as password. For more information about creating personal access tokens, see the Github documentation.
      • To clone and push with SSH authentication (SSH private key): git@github.com:cloudera/ssb-examples.git
        In case of using SSH authentication, you need to generate the private key using the following command:
        ssh-keygen -t ecdsa -b 256 -m pem -C "name@example.com"
        As not every SSH private key is supported, you can use the following command to convert your key to the acceptable format:
        ssh-keygen -m pem -p -f [***PATH_TO_PRIVATE_KEY***]
      • To clone and push a local git repository on the filesystem of SSB host: file:///usr/src/ssb-examples/
    2. Provide the branch name or tag of the Github repository to the Branch field. This branch is checked out when pulling or pushing to the Github repository.
  7. Enable or disable Allow deletions on import.
  8. Enable or disable Authentication for the project.
After you have created the project, you have the following options to manage the project on the Projects page:
  1. Click Open to use the created project and start creating SQL jobs.
  2. Click Switch to open another project than the active one.
  3. Click Delete to remove the project from Cloudera SQL Stream Builder.
