Filesystem connector
When using the Filesystem connector, you can choose between HDFS, S3 and so on storage systems. Based on the connector type you choose, there are mandatory fields where you must provide the correct information.
Template: filesystem
Using either HDFS, S3 or any type of storage system. When you use the Filesystem connector, you must specify the path to the file system which are going to be used for the connection.
Type: source/sink
The following fields are mandatory to use the connector:
  • path: Path to the root directory of the table data. No default value is specified.
  • format: The format used for the file system. No default value is specified.
