Other supported statements
Beside the supported DDL, DML and SELECT, the supported statements also include DESCRIBE, SHOW and SET that you can use in SQL Stream Builder.
The following table summarizes the supported statements for in SQL Stream Builder:
Operation Description
DESCRIBE TABLES Describing the schema of a table
SHOW TABLES Showing a list of existing tables, views, functions, databases or catalogs
SHOW VIEWS
SHOW FUNCTIONS
SHOW DATABASES
SHOW CATALOGS
SET Setting properties of session
For more information about Flink SQL, see the Apache Flink documentation.
