Resuming Flink applications
After updating the Cloudera Streaming Analytics artifacts, you can resume your application by the Flink run command. In case you have stopped your application by creating a savepoint, you must add the savepoint location to the command.
Resuming Flink applications without state
- Connect to your host where you run your Flink jobs using
ssh.ssh root@[***FLINK HOSTNAME***] Password:[***PASSWORD***] - Submit your Flink application that was stopped before the
upgrade.
flink run [***RUN ARGUMENTS***] \ [***JAR FILE***] [***APP ARGUMENTS***]
Resuming stateful Flink applications
upgrade.
flink run [***RUN ARGUMENTS***] \ -fromSavepoint hdfs:///tmp/savepoints/[***SAVEPOINT NAME***] \ [***JAR FILE***] [***APP ARGUMENTS***]
