Setting up Oracle database for Cloudera SQL Stream Builder
After installing Oracle database server, you must rename the JDBC connector, and create a database with credentials for Cloudera SQL Stream Builder before installing the service on your cluster. You also must install the Oracle Python connector to integrate with the Streaming SQL Engine.
Before you begin
You need to install and configure Oracle database, before setting up the databases for Cloudera SQL Stream Builder. To install and configure Oracle DB, you must complete the basic steps mentioned in the Cloudera Base on premises documentation.
Installing the Oracle JDBC connector
- Download the Oracle JDBC Driver from the Oracle website.
 - Rename the JDBC jar file to
oracle-connector-java.jar.mv ojdbc8-19.3.0.0.jar oracle-connector-java.jar - Copy the Oracle JDBC jar file to your host.This host must be the same host where you plan to assign the Streaming SQL Engine service role. The service roles are assigned as a next step when installing Cloudera SQL Stream Builder as a service in Cloudera Manager.
You will be prompted to provide your password.scp <location>/oracle-connector-java.jar root@<your_hostname>: - Access the host on your cluster.This host must be the same host where you have added the JDBC jar file.
You will be prompted to provide your password.ssh root@<your_hostname> - Copy the Oracle JDBC jar file to
/usr/share/javafolder using the following command:sudo mkdir -p /usr/share/java sudo cp <location>/oracle-connector-java.jar /usr/share/java sudo chmod 644 /usr/share/java/oracle-connector-java.jar - Check if the Oracle connector is in the folder with
lscommand.
Creating Oracle database for Cloudera SQL Stream Builder
- Access a host on your cluster.This host must be the same host where you plan to assign the Streaming SQL Engine service role. The service roles are assigned as a next step when installing Cloudera SQL Stream Builder as a service in Cloudera Manager.
You will be prompted to provide your password.ssh root@<your_hostname> - Log in to the Oracle
                        client:
sqlplus system@localhost Enter password: ****** - Create a user and schema for Streaming SQL
                        Engine:
create user ssb_admin identified by <password> default tablespace ssb_admin; grant CREATE SESSION to ssb_admin; grant CREATE TABLE to ssb_admin; grant CREATE SEQUENCE to ssb_admin; grant EXECUTE on sys.dbms_lob to ssb_admin; - Grant a quota on the ssb_admin tablespace where the tables will be
                            created:
ALTER USER ssb_admin quota 100m on ssb_admin;You can also create unlimited space with the following command:ALTER USER ssb_admin quota unlimited on ssb_admin; - Confirm that you have created the Streaming SQL Engine and Materialized View
                        Engine database using the
\lcommand.
