Release NotesPDF version
System Requirements
Before installing Cloudera Streaming Analytics, you should verify that you meet the system requirements. Other than Cloudera Base on premises, you should also check the latest supported version of the needed components.
For detailed information about the supported versions of Cloudera Base on premises, operating systems and databases, see the Cloudera Support Matrix.
Apache Flink support 1.19.1
Cloudera Runtime component support in Cloudera Base on premises 7.3.1
Atlas 2.1.0
HBase 2.4.17
HDFS 3.1.1
Hive 3.1.3
Kafka1 3.4.1
Kudu 1.17.0
Schema Registry 0.10.0
Streams Messaging Manager 2.3.0
Apache Iceberg 1.3.1
Connector support
JDBC PostgreSQL 9.6-16
JDBC MySQL 5.7, 8
JDBC Hive 3.1.3
JDBC Oracle 19, 19c, 21c, 23c
JDBC Db2 11.5
JDBC SQL Server 2007-2022
CDC PostgreSQL 9.6-16
CDC MySQL 5.7, 8
CDC Oracle 19, 19c, 21c, 23c
CDC Db2 11.5
CDC SQL Server 2007-2022
1 Connecting to Kafka that is running on remote CDH6 or HDP3 is also supported.
