Exporting SQL projects
You can use source control to create a backup from your Cloudera SQL Stream Builder projects. After the upgrade is successful, you can import the projects on Streaming SQL Console.
          Open a project from the Projects page of Streaming SQL
            Console.
- Select an already existing project from the list by clicking the Open button or Switch button.
 - Create a new project by clicking the New Project button.
 - Import a project by clicking the Import button.
You are redirected to the Explorer view of the project. -
                Click Source Control.
                You can configure the source control settings with the following steps, if the source control is not configured yet:
                        Add a remote Github repository URL to the Clone
                                URL field.
- To clone without authentication:
https://github.com/cloudera/ssb-examples.git - To clone and push with HTTP basic authentication
                                    (username/password):
https://github.com/cloudera/ssb-examples.gitIn case of using basic authentication, the personal access token needs to be provided as password. For more information about creating personal access tokens, see the Github documentation.
 - To clone and push with SSH authentication (SSH private key):
git@github.com:cloudera/ssb-examples.gitIn case of using SSH authentication, you need to generate the private key using the following command:
As not every SSH private key is supported, you can use the following command to convert your key to the acceptable format:ssh-keygen -t ecdsa -b 256 -m pem -C "name@example.com"ssh-keygen -m pem -p -f [***PATH_TO_PRIVATE_KEY***] - To clone and push a local git repository on the filesystem of
                                    SSB host:
file:///usr/src/ssb-examples/
 - Provide the branch name or tag of the Github repository to the Branch field. This branch is checked out when pulling or pushing to the Github repository.
                                URL field.
 - Provide a commit message.
 - Click Push.
 - Review that the commit appears in the repository you pushed the change.
