Configuring Materialized View database information
In Cloudera Base on premises, PostgreSQL is configured during the installation of Cloudera SQL Stream Builder as a service. You can review the database configuration for Cloudera SQL Stream Builder using
Cloudera Manager.
Cloudera SQL Stream Builder uses PostgreSQL database to store the queried data of the
Materialized View feature. In Cloudera Base on premises, you can only use PostgreSQL as a
database for Cloudera SQL Stream Builder. In case you need to connect to the PostgreSQL database of Cloudera SQL Stream Builder, you can
review the necessary information of the database in Cloudera Manager. You can also configure
the user and the password of the database using CLI, and then updating the existing
information in Cloudera Manager.
Where to find the PostgreSQL database information?🔗
Select Cloudera SQL Stream Builder from the list of services
Click Configuration.
Filter down the configuration parameters to Materialized View
Engine.
The following information is listed about the PostgreSQL
database:
Database Name
Database Host
Database Port
Database User
Database Password
When you want to change the default configuration of PostgreSQL database, first you
need to change the information in PostgreSQL and then update the configuration in Cloudera Manager for Cloudera SQL Stream Builder.
