Monitoring Enabling Flink DEBUG loggingYou can review the log text files of the Flink jobs when an error is detected during the processes. When you set the log level of Flink to DEBUG, you can easily trace the log file for errors.Flink DashboardThe Flink Dashboard is a built-in monitoring interface for Flink applications in Cloudera Streaming Analytics. You can monitor your running, completed and stopped Flink jobs on the dashboard. You reach the Flink Dashboard through Cloudera Manager.Streams Messaging Manager integrationYou can use the Streams Messaging Manager (SMM) UI to monitor end-to-end latency of your Flink application when using Kafka as a datastream connector.Using the OpenTelemetry Collector with Flink [Technical Preview]The OpenTelemetry metrics reporter makes it easier and more efficient to aggregate Flink jobs' metrics to a central OpenTelemetry-compatible service using open standards.
