Kudu with Flink
Cloudera Streaming Analytics offers Kudu connector as a sink to create analytical application solutions. Kudu is an analytic data storage manager. When using Kudu with Flink, the analyzed data is stored in Kudu tables as an output to have an analytical view of your streaming application.
You can read Kudu tables into a DataStream using the KuduCatalog with Table API or using the KuduRowInputFormat directly in the DataStream. The difference between the two methods is that when using the KuduRowInputFormat, you need to manually provide information about the table.
For more information about the Kudu sink in DataStream API, see the official documentation.
Kerberos and long-running jobs
On Kerberos-secured clusters, long-running Flink jobs that read from or write to Kudu tables can fail with authentication errors when a Kerberos ticket expires or after a Kudu or Flink cluster restart. Enable Hadoop keytab login autorenewal by passing the following property when you submit the job with the Flink CLI:
-yD flink.hadoop.hadoop.kerberos.keytab.login.autorenewal.enabled=true
