System Requirements
Before installing Cloudera Streaming Analytics, you should verify that you meet the system requirements. Other than Cloudera Base on premises, you should also check the latest supported version of the needed components.
For detailed information about the supported versions of Cloudera Base on premises, operating systems and databases, see the Cloudera Support Matrix.
| Apache Flink support | 1.20.1 |
| Cloudera Runtime component support in Cloudera Base on premises 7.3.1 | |
| Atlas | 3.0.0 |
| HBase | 2.4.17 |
| HDFS | 3.1.1 |
| Hive | 3.1.3 |
| Kafka1 | 3.4.1 |
| Kudu | 1.17.0 |
| Schema Registry | 0.10.0 |
| Streams Messaging Manager | 2.3.0 |
| Apache Iceberg | 1.5.2 |
supported.
| Connector support | |
| JDBC PostgreSQL | 9.6-16 |
| JDBC MySQL | 5.7, 8 |
| JDBC Hive | 3.1.3 |
| JDBC Oracle | 19, 19c, 21c, 23ai |
| JDBC Db2 | 11.5 |
| JDBC SQL Server | 2007-2022 |
| CDC PostgreSQL | 9.6-16 |
| CDC MySQL | 5.7, 8 |
| CDC Oracle | 19, 19c, 21c, 23ai |
| CDC Db2 | 11.5 |
| Apache Iceberg | 1.3.0 |
