Configuring Kafka tables
The user-defined Kafka table can be configured based on the schema, event time, and
other Kafka-specific properties by using either the Kafka wizard or DDL.
Schema Definition tab When using the Add Kafka table wizard on the Streaming SQL Console, you can configure the schema under the Schema tab.Event Time tab When using the Add Kafka table wizard on the Streaming SQL Console, you can configure the event time under the Event Time tab.Properties tab When using the Add Kafka table wizard on the Streaming SQL Console, you can configure the properties under the Properties tab.Deserialization tab When creating a Kafka table, you can configure how to handle errors due to schema mismatch using DDL or the Kafka wizard.Assigning Kafka keys in streaming queries Based on the Sticky Partitioning strategy of Kafka, when null keyed events are sent to a topic, they are randomly distributed in smaller batches within the partitions.Performance & Scalability The Kafka and Cloudera SQL Stream Builder integration enables you to use the Kafka-specific syntax to customize your SQL queries based on your deployment and use case.
