System Requirements
Before installing Cloudera Streaming Analytics, you should verify that you meet the system requirements. Other than Cloudera Base on premises, you should also check the latest supported version of the needed components.
Java / JDK requirements
Support for JDK 8 and JDK 11 has been removed. Cloudera Streaming Analytics 1.17.1 only supports JDK 17 and JDK 21.
Component and connector versions
For detailed information about the supported versions of Cloudera Base on premises, operating systems and databases, see the Cloudera Support Matrix.
Apache Flink support 1.20.1
Cloudera Runtime component support in Cloudera Base on premises 7.3.2 CHF1
Atlas 2.4.7
HBase 2.6.3
HDFS 3.4.2
Hive 3.1.3000
Kafka1 3.9.1
Kudu 1.18.0
Schema Registry 0.10.0
Streams Messaging Manager 2.3.0
Apache Iceberg 1.5.2
1 Connecting to Kafka that is running on remote CDH6 or HDP3 is also supported.
Connector support
JDBC PostgreSQL 9.6-16
JDBC MySQL 5.7, 8
JDBC Hive 3.1.3
JDBC Oracle 19, 19c, 21c, 23ai
JDBC Db2 11.5
JDBC SQL Server 2007-2022
CDC PostgreSQL 9.6-16
CDC MySQL 5.7, 8
CDC Oracle 19, 19c, 21c, 23ai
CDC Db2 11.5
CDC SQL Server 2007-2022
MariaDB (*) 11.x
