For installing Cloudera Streaming Analytics (CSA), you need to upload the downloaded
Flink and SQL Stream Builder (SSB) Custom Service Descriptor (CSD) files to the default CSD
directory, and add the CSA parcel to your cluster using Cloudera Manager.
Download the Flink and SSB CSD and parcel files.
Install CDP Private Cloud Base.
Place the CSD files in the /opt/cloudera/csd/ folder (default
CSD directory).
This way Cloudera Manager will automatically detect the CSD
files.
Restart Cloudera Manager and CMS services for the changes to take effect.
> systemctl restart cloudera-scm-server
Log into Cloudera Manager.
Select Parcels on the Home > Hosts tab in the main navigation bar.
Click the Parcel Repositories & Network Settings
tab.
Check that Cloudera Manager successfully auto-detected the Remote
Parcel Repository URL for CSA.
Enter your download credentials to HTTP authentication username
override for Cloudera Repositories and HTTP
authentication password override for Cloudera
Repositories.
Click Save & Verify Configuration to commit the
change.
Click Close.
You will be redirected to the Parcels page.
Search for Flink and click Download to download the
parcel to the local repository.
After the download is completed, click Distribute to
distribute the parcel to all clusters.
After the parcel is distributed, click Activate to
activate the parcel.
Click OK when confirmation is required.
For more details, follow the standard procedure from the GUI or the
API.
You have added Flink and SSB CSD files, and the parcel to
your cluster. Add Flink as a service in Cloudera Manager. After adding Flink as a service, you
are able to add SSB service to your cluster.
