After installing Kudu as a service on your cluster, you can add it as a Catalog in
SQL Stream Builder (SSB) to use it in Flink DDL.
- Make sure that you have Kudu service on your cluster.
Click SQL Stream Builder from the list of
services.
Click Data Providers from the main menu.
Click Register Catalog.
The Add Catalog window appears.
Add a Name to your catalog.
Select Kudu from the Catalog Type drop-down.
Add the Host URL of Kudu Masters.
Select Kudu from the list of services.
Click on Instances.
Copy the Hostname of the Master Default Group.
Add the default port of Kudu after the hostname.
Example:
http://docs-test-1.vpc.cloudera.com:7051
Click on Add Filter.
Provide a Database and
Table filter if you want to select specific
tables to use from the catalog.
Click on Validate.
If the validation is successful, click Add Tables.
Kudu is added as a Catalog and ready to be used in Flink
DDL. The already existing tables in Kudu are automatically imported to SSB.
