Managing registered Data Providers
You can edit or delete the registered Data Providers if you need to change their configurations or if you no longer need them.
Editing registered Data Providers
  2. Click SQL Stream Builder from the list of services.
  4. Click Data Providers from the main menu.
  5. Search for the Kafka provider or catalog you want to modify.
  6. Click Edit.
    The Edit Provider or Catalog window appears.
  7. Change the settings as required.
  8. Click Save Changes.
Deleting registered Data Providers
  6. Click Delete.
  7. Click Confirm to delete the provider or catalog.
