You can use custom catalogs in cases when you need to add a catalog that is not
predefined in the Streaming SQL Console, and when more advanced settings need to be
specified for the catalogs. This case you need to provide the configuration directly to
Flink with the custom catalog option.
Click SQL Stream Builder from the list of
services.
Click Data Providers from the main menu.
Click Register Catalog.
The Add Catalog window appears.
Add a Name to your catalog.
Select Custom from the Catalog Type drop-down.
Provide a Property Name and Value
for the Catalog.
Click on Add Filter.
Provide a Database and
Table filter if you want to select specific
tables to use from the catalog.
Click on Validate.
If the validation is successful, click Add Tables.
The custom catalog is added and ready to be used in Flink
DDL.
