After installing Hive as a service on your cluster, you can add it as a Catalog in
SQL Stream Builder (SSB) to use it in Flink DDL.
- Make sure that you have Hive service on your cluster.
Click SQL Stream Builder from the list of
services.
Click Data Providers from the main menu.
Click Register Catalog.
The Add Catalog window appears.
Add a Name to your catalog.
Select Hive from the Catalog Type drop-down.
Click on Add Filter.
Provide a Database and
Table filter if you want to select specific
tables to use from the catalog.
Click on Validate.
If the validation is successful, click Add Tables.
Hive is added as a Catalog and ready to be used in Flink
DDL. The already existing tables in Hive are automatically imported to SSB.
