You can configure the webhook table to perform an HTTP action per message (default)
or to create code that controls the frequency (for instance, every N messages). When
developing webhook sinks, it is recommended to check your webhook before pointing at your
true destination.
Click SQL Stream Builder from the list of
Services.
Select Console from the main menu.
Select the Tables tab.
Select Add table > Webhook.
The Webhook Table window appears.
Provide a name to the Table.
Enter an HTTP endpoint. The endpoint must start with http://
or https://.
Add a Description about the webhook sink.
Select POST or PUT in the HTTP
Method select box.
Choose to Disable SSL Validation, if needed.
Enable Request Template, if needed.
If you selected Yes, then the template defined
in the Request Template tab is used for output.
This is useful if the service you are posting requires a particular
data output format. The data format must be a valid JSON format, and use
"${columnname}" to represent fields. For example, a
template for use with Pagerduty looks like
this:
"incident":{
"type":"incident",
"title":"${icao} is too high!",
"body":{
"type":"incident_body",
"details":"Airplane with id ${icao} has reached an altitude of ${altitude} meters."
In the Code editor, you can specify a code block that controls how the webhook
displays the data.
For a webhook that is called for each message the following code is
used:
// Boolean function that takes entire row from query as Json Object
function onCondition(rowAsJson)
{return true; // return false here for no-op, or plug in custom
logic}
onCondition($p0)
Add HTTP headers using the HTTP Headers tab, if
needed.
Headers are name:value header elements. For instance,
Content-Type:application/json, etc.
Click Save Changes.
The Webhook table is ready to be used as sink in the SQL
Stream jobs. You can add the created table on the Compose tab by
selecting its name from the list of Sink Tables.
