After executing a SQL Stream job, you can set up the Materialized Views to have a
snapshot of your queried data. You can use the URL Pattern from the Materialized View to
visualize the generated data.
Make sure that PostgreSQL is installed and configured
to SQL Stream Builder (SSB) to create Materialized Views.
You need to have a running SQL job on which you apply the Materialized Views
configuration.
Select SQL Stream Builder from the list of
services.
Run a SQL Stream job, and wait until data is shown on the results tab.
For more information on running a SQL job, see the Running a SQL Stream job
documentation.
Select the Materialized View sub-tab on the Compose
tab.
Select Enabled for Materialized View.
Select a Primary Key.
If this list is empty, then no SQL is specified on the SQL sub-tab, or that
SQL is invalid. Select a key as a primary key for the Materialized View. All
data will be updated by this key.
Select a Retention Period.
Data not being mutated during this period is removed from the view.
Enable or disable Recreate on Job Start.
If enabled, the Materialized View is deleted when a job is started or
restarted.
Enable or disable Ignore NULLS.
If enabled, NULL values will NOT update values that are non null - they are
ignored.
Select an API Key.
In case there are no API Keys, click Add API key, or
click Materialized Views from the main menu. The add API
key window appears. Provide a name for the API key, and click Save Changes.
To check your created API keys:
Click Materialized Views from the main
menu.
The Materialized Views page appears.
Click [show] under Key to see the API Key.
Click Advanced Settings for more configureation.
Set Delete data to True to
delete and recreate the Materialized View when restarting the SQL job.
This setting is needed when the schema is changed for a job.
Click Apply Configuration.
Click Add Query to create the Materialized View
query.
The Materialized View Query Configuration window appears.
Provide a name to the URL Pattern.
Provide a description of the Materialized View Query, if needed.
Customize the Materialized View in the Query Builder.
Select the columns of the SQL job you want to use in the Materialized
View Query.
Click Add filters to apply computations and
further enrichment of your data.
Click Add rule to save the filter.
Click Save Changes.
The Pattern URL appears under Materialized View Queries header.
You can click the created REST endpoint to review the data,
or copy it and visualize the queried data in a Business Intelligence tool, notebook,
code and so on.
