High Availability for SQL Stream Builder (SSB) SSB can be enabled using a Load
Balancer. To enable the Load Balancer for SSB after the SSB service is installed, you need
to add the Load Balancer instance to the SSB cluster.
Select SQL Stream Builder from the list of
services.
Click .
The Add Role Instances wizard is displayed.
On the Assign Roles page, click Select hosts for Load Balancer.
Select a host and click OK.
You can add additional SQL Stream Engine and Materialized View Engine servers
to boost performance:
Select hosts for SQL Stream Engine.
Select hosts for Materialized View Engine.
Click .
Click Continue.
The newly added hosts are displayed on the Instances tab.
Select all the newly added hosts.
Click .
Update the Load Balancer URL and Host.
Click Configuration.
Search for load-balancer url.
Provide the host url where the SSB service is installed.
Restart Cloudera Manager.
sudo service cloudera-scm-server restart
Access the Streaming SQL Console with Load Balancer.
services.
Click .
You have a load balanced instance of SSB. You can reach the
load balanced instance of Streaming SQL Console from the SSB service page in Cloudera
Manager.
