Materialized View Pagination
You can set a limit and order the results of a Materialized View query by adding values to the limit and offset configurations.
After creating a Materialized View, you can order and limit the results after opening the Materialized View. The default limit of the results is 100 entries. You can set the limit and offset using the REST URL. You need to modify the URL address in your browser by setting the value and the offset value as shown in the following example:
http://csa-test-2.vpc.cloudera.com:18131/api/v1/query/5275/locations?key=6ef33a7a-c82a-4a72-946b-5fe0b33e033c&limit=20&offset=3
When you edit the Materialized View, the set limit and offset change based on the new filters set for the Materialized View query. If you set an invalid number for the limit and offset, an error message is displayed.
