You need to add Cloudera Schema Registry, Kudu, Hive, Confluent Schema Registry or other services as a Catalog using the Streaming SQL
Console in SQL Stream Builder (SSB) to use them with Flink DDL.
Make sure that you have the required service on your cluster.
Make sure that you have the right permissions set in Ranger for SSB and the
services.
Select SQL Stream Builder from the list of services.
Open a project from the Projects page of Streaming SQL
Console.
Select an already existing project from the list by clicking the
Open button or Switch button.
Create a new project by clicking the New Project
button.
Import a project by clicking the Import button.
Open Data Sources from the
Explorer view.
Click next to Catalogs.
Select New Catalog.
The Add Catalog window appears.
Select the Catalog Type from the following
options:
Select Schema Registry from the
Catalog Type drop-down.
Select the Kafka cluster you registered
as Data Source.
Enable TLS, if needed for the communication.
If you enabled TLS, provide the Schema Registry
Truststore location and password to the SR
TrustStore and SR TrustStore
Password field.
Add the Schema Registry URL.
list of services.
Click on Instances.
Copy the Hostname of Schema Registry.
Add the default port of Schema Registry after the
hostname.
Example:
http://docs-test-1.vpc.cloudera.com:7788/api/v1
Select Kudu from the Catalog Type
drop-down.
Add the host URL of Kudu Masters.
Select Kudu from the list of
services.
Click on Instances.
Copy the Hostname of the Master Default Group.
Add the default port of Kudu after the
hostname.
Example:
http://docs-test-1.vpc.cloudera.com:7051
Select Hive from the Catalog Type
drop-down.
Provide the name of the Hive Default
Database.
Select Confluent Schema Registry from the
Add a Name to your catalog.
as Data Source.
Add the Confluent Cloud Schema Registry URL provided by your
Confluent connection configurations.
Choose an Authentication method from the following:
BASIC
If the basic authentication method is selected,
you must provide the username and password.
CUSTOM
Custom authentication methods include bearer
authentication, SSL authentication and so on. If
the custom authentication method is selected, you
must provide the authentication property keys to
the Custom Properties field
as they are set for the Confluent Cloud Schema
Registry. For example, if the Confluent Cloud
Schema Registry is configured with bearer
authentication, you need to provide the
bearer.auth.credentials.source
and bearer.auth.token. If SSL
authentication is configured, the
schema.registry.ssl.keystore.location,
schema.registry.ssl.keystore.password
and so on must be provided.
Select Custom from the Catalog Type
drop-down.
Provide a Property Key.
Proivde a Property Value.
If needed,
you can specify more custom properties by using the
plus icon.
Click on Add Filter.
Provide a Database and
Table filter if you want to select specific
tables to use from the catalog.
Click on Validate.
If the validation is successful, click Create.
You are ready to use the added catalog in SSB with Flink
DDL. The already existing schemas in Schema Registry and Confluent Schema Registry,
tables in Kudu and Hive are automatically imported to SSB.After registering a catalog, you can edit, duplicate and
delete it from Streaming SQL Console:
Explorer view.
Select Manage.
The Catalogs tab
opens where the registered catalogs are listed. You have the following
options to manage the catalog sources:
Click on one of the existing catalogs to edit its configurations.
Click to remove the catalog.
Click to duplicate the catalog with
its configurations.
