Searching for assets in Data Catalog using additional search options
Consider a scenario in Data Catalog, where you select a data asset type and under the Asset Details page, you insert a comment and provide the description for the selected asset.
Navigate to the Data Catalog search query pane and enter the Comment and Description value(s) that you saved for the selected asset type in Data Catalog. The result page displays the asset type that you added for the Comment and Description fields in Data Catalog.
When you query for the entered Comment value for the selected asset type in Data Catalog, the relevant asset type is displayed in the search result page.
![](../images/dc-search-option-3.png)
![](../images/dc-search-option-4.png)
Clicking on the asset type in Data Catalog displays the comment and description values as it was assigned in Data Catalog.
When you query for the entered Description value for the selected asset type in Data Catalog, the relevant asset type is displayed in the search result page.
![](../images/dc-search-option-1.png)
![](../images/dc-search-option-2.png)
Your search query displays the results.
