Tagging Multiple Assets
On the Search page, you can add tags to multiple assets based on the asset type that you select based on the search result.
When you select an asset, you can add one or more available tags to the selected asset. You can also create one or more new tags and associate the newly created tags to the selected asset. The number of selected assets that you plan to tag is displayed. As you add the number of tags to one or more selected assets, the Add Tags panel displays the number of tags assigned.
When you add one or more tags to the selected entities, the assigned tags are displayed having been tagged to the number of selected entities. You are warned if the selected asset is already tagged.
