Deleting profilers
Deleting the profiler container (pod) jobs removes all the Custom Sensitivity Profiler rules and other updates to the specified profiler.
To overcome this situation, when you decide to delete the profiler jobs, there is a provision to retain the status of the Cluster Sensitivity Profiler rules:
  • If your profiler jobs have rules that are not changed or updated, you can directly delete them.
  • If the rules were modified or updated, you have an option to download the modified rules along with deletion. The modified rules consist of the suspended system rules and the deployed custom rules. Using the downloaded rules, you can manually add or modify them to your newly added profiler jobs or the profiler cluster.
  1. On the Search page, select the data lake.
  2. Click the Actions drop-down menu and select Delete Cluster.
  3. Click Yes to proceed.
  4. If you agree, select the warning message I understand this action cannot be undone.
  5. Click Delete.
    The application displays the following message.
    The profiler cluster is deleted successfully.
