Managing Datasets
You can view, create, edit, and delete datasets to manage and govern various kinds of data objects as a single unit through a unified interface.
In Cloudera Data Catalog, click Datasets to view all the datasets.
Search for Datasets
On the Datasets page, enter a search string in the search box to view all asset collections with names or descriptions that contain the search string.
Filter Datasets by Tags
You can view and filter datasets with tags added during dataset creation. Select the tag from the drop down list or enter the tag in the filter box. Any dataset with the filter tag assigned to a column will appear in the results.
