Propagated asset tagging
Cloudera Data Catalog supports the concept of propagated tags. This feature is derived from Apache Atlas.
Whenever you add a new tag in Atlas, you can mark them as propagated and use those tags accordingly while tagging assets.
For example, consider table1 as a parent asset and table2 as a child asset. Create a tag and mark that tag as propagated, and later apply the same tag to table1. The tag gets applied to table2 as well. Propagated tag works on the basis of parent -> child tagging relationship.
