Tracking profiler jobs
Use the Profilers > Jobs page for tracking respective profiler jobs.
Under Profilers > Jobs, you can have an overview of your started profiler jobs. By using the D, W, M filters, you can go back up to a day, week or a moth, to see your previous jobs. Use this page to quickly check if your profiler jobs are failing.
For each profiler job, you can view the details about:
  • Profiler type
  • Job Status
  • Job ID
  • Start Time
  • Last Updated time
Using this data can help you to troubleshoot failed jobs or even understand how the jobs were profiled and other pertinent information that can help you to manage your profiled assets.
In case of Ranger Audit profiling, there could be a “NA” status for the total number of assets profiled. It indicates that the auditing that happens is dependent on the Ranger policies. In other words, the Ranger policies are actually profiled and not the assets.
