Tagging multiple assets
On the Search page, you can add tags (Atlas classifications) to multiple assets based on the asset type that you select based on the search result.
When you select an asset, you can add one or more available tags to the selected asset. You can also create one or more new tags and associate the newly created tags to the selected assets. The number of tags including the ones applied and to be applied is displayed.
