Enabling or disabling profilers
Learn how to enable or disable profilers in Cloudera Data Catalog to manage resource usage effectively.
- Go to Profilers.
- Click
> Disable Profiler.
- Click Confirm.
- You can click Enable Profiler to continue using
it.
Go to .
Select the profiler to proceed further.
Switch the toggle to the desired state.
