Viewing profiler configurations
You can monitor the last status of individual profilers. Also, you can change their resources, sensitivity and scheduling.
You can check the configuration and its changes for your profiles in Profilers > Profiler Details > Configuration.
By clicking by the individual jobs in Profilers Details, you can drill further down to Job Summary and Profiled Assets.
The Job Summary shows you the specific configuration applied for that particular job run.
You can monitor the last status of individual profilers by viewing them in Profiler > Configs. Also, you can change their resources, sensitivity and scheduling.
Monitoring the profiler configurations has the following uses:
  • Verify which profilers are active or inactive.
  • Verify the status of the profiler runs.
  • View the last run time and status and the next scheduled run.
