About the back up script
The Backup and Restore script can be used only on Amazon Web Services, Microsoft Azure, and Google Cloud Platform clusters where they support cloud storage.
Scenarios for using the script
- When you upgrade the data lake cluster and want to preserve profiler data in the Cloudera Data Hub cluster.
- When you want to delete the Cloudera Data Hub cluster but preserve the profiler data.
- When you want to relaunch the profiler and access the older processed data.
Go to the following locations to pick up your scripts:
- Back up
bash /opt/cloudera/parcels/PROFILER_MANAGER/profileradmin/scripts/users/backup_db.sh- Restore
bash /opt/cloudera/parcels/PROFILER_MANAGER/profileradmin/scripts/users/restore_db.sh
When upgrading a version below or equal to Cloudera Runtime version 7.2.11 to 7.2.12:
- Back up
bash /opt/cloudera/parcels/CDH/lib/profiler_manager/profileradmin/scripts/users/restore_db.sh
When backing up and restoring for a cluster having the Cloudera Runtime version 7.2.12 and onwards:
Navigate to the following location to pick up your scrips:
- Back up
bash /opt/cloudera/parcels/CDH/lib/profiler_manager/profileradmin/scripts/users/backup_db.sh- Restore
