Setting up column name based tagging
In VM-based environments with Cloudera on cloud 7.2.18.500 or later, you can use column name based tagging to ensure profiling columns whose data quality might not trigger the column value based checks of the Cluster Sensitivity Profiler. Typically, this can be used for tables where a large ratio of rows contain a different type of data or no data at all compared to the targeted data type that needs to be profiled.
A new classification must be created in Apache Atlas in advance. This classification (called tag in Cloudera Data Catalog) will be matched with tag rules to trigger the profiling. For more information, see Creating classifications.
