Profiler data testing
You must note the important information about profiler services.
Test data for VM-based environments
The following dataset has been validated and works as expected:
- DataHub Master: m5.4xlarge
- Hive tables: 3000 Hive assets
- Total Number of assets (including Hive columns, tables, databases): 1,000,000
- Total Data Size = 1 GB
- Partitions on Hive tables: Around 5000 partitions spread across five tables
