Customizing the help menu through the settings file
You can customize the Help menu on the main navigation bar by deleting default links provided by CDP Data Visualization, or by adding new links.
To customize the Help menu, modify the local configuration file, such
as settings.py
, and restart the server.
Components of the Help Menu
By default, the Help menu contains links to What's New in the current release, Documentation, Knowledge Base, YouTube Channel, Support Email, licensing status, and the current version of CDP Data Visualization.
To modify this menu, you must change the corresponding settings from TRUE
to FALSE
- HELP_SHOW_WHATSNEW
Set to
TRUE
to show the release number of the running instance of CDP Data Visualization.HELP_SHOW_WHATSNEW = True
This is
TRUE
by default. To remove the "What's new" link, set the parameter toFALSE
:HELP_SHOW_WHATSNEW = False
- HELP_SHOW_DOCUMENTATION
Set to
TRUE
to show the link to our documentation atdocumentation.arcadiadata.com/release_number/
.HELP_SHOW_DOCUMENTATION = True
This is
TRUE
by default. To remove the "Documentation" link, set the parameter toFALSE
:HELP_SHOW_DOCUMENTATION = False
- HELP_SHOW_SUPPORT_EMAIL
Set to
TRUE
to show a link to contact our support team at support@arcadiadata.com.HELP_SHOW_SUPPORT_EMAIL = True
This is
TRUE
by default. To remove the "Support" link, set the parameter toFALSE
:HELP_SHOW_SUPPORT_EMAIL = False
- HELP_SHOW_VERSION
Set to
TRUE
to show the release number of the running instance of CDP Data Visualization.HELP_SHOW_VERSION = True
This is
TRUE
by default. To remove the version, set the parameter toFALSE
:HELP_SHOW_VERSION = False
- HELP_SHOW_LICENSE
Set to
TRUE
to show if your license is valid.HELP_SHOW_LICENSE = True
This is
TRUE
by default. To remove the license information, set the parameter toFALSE
:HELP_SHOW_LICENSE = False
- HELP_MENU_LINKS
To add custom links that supplement the default Arcadia help links, use the
HELP_MENU_LINKS
parameter and a list of links in the form oftype:link
,link:url_address
, andlabel:link_label
.You can also insert a divider between these custom links, in the form:
type:divider
,HELP_MENU_LINKS = [ { "type": "link", "link": "url_address_1", "label": "link_label_1", } { "type": "link", "link": "url_address_2", "label": "link_label_2", } ... { "type": "divider", } { "type": "link", "link": "url_address_n", "label": "link_label_n", } ]
Sample Help Menu Configuration
Here is a sample of configuration settings for the Help menu:
# To display the default Arcadia help links in the Help menu, set the flag to "True"
# To remove an Arcadia link from the Help menu, set the flag to "False"
# To add new links in the Help menu, enter the following code:
#In this example, we are adding links to Knowledge Base and YouTube Channel.
HELP_MENU_LINKS = [
"type": "link",
"link": "https://www.arcadiadata.com/resources/knowledge-base/",
"label": "Knowledge Base",
# You can also specify a divider between the two rows as follows:
# "type": "divider",
"type": "link",
"link": "https://www.youtube.com/channel/UCmubDZSISQMKg1Q0HXo03HQ",
"label": "YouTube Channel",
