Advanced concurrency settings
Cloudera Data Visualization allows users with administration privilages to change the per user and per connection concurrency settings.
- Scroll down to the Advanced Site Settings, at the bottom of the Site Settings page.
Enter the desired concurrency settings in
key = value
format with the following options available:Option Description DATACONNECTION_CONCURRENCY_DEFAULT
The default number of concurrent requests per data connections. DATACONNECTION_CONCURRENCY_MAX
The maximum number of concurrent requests per data connections. DATACONNECTION_CONCURRENCY_USER_DEFAULT
The default number of concurrent requests per user. DATACONNECTION_CONCURRENCY_USER_MAX
The default number of maximum concurrent requests per user.
