Advanced settings for data extracts
Cloudera Data Visualization allows users with administration privileges to change data extracts settings.
  1. Click the Gear icon to open the Site Administration menu and select Site Settings.
  2. Scroll down to the Advanced Settings at the bottom of the Site Settings page.
  3. Enter the desired settings in key = value format.
    The following options are available:
    Prefix for target table names
    You can define a prefix for table names. The default value is cdv_.
    DATA_EXTRACTS_TARGET_TABLENAME_PREFIX = "cdv_"
    Maximum number of rows that can be inserted into a data connection by CDV using data extracts or CSV upload
    You can set a system wide maximum value for the maximum number of rows for upload/import all connections.
    UPLOAD_MAXROWS_MAX = 1000000000
    You can set the default value for the maximum number of rows for upload/import for all connections. You can change the default on each connection in the Edit connection modal. Its value can be only between 0 and UPLOAD_MAXROWS_MAX.
    UPLOAD_MAXROWS_DEFAULT = 1000000
    Number of rows inserted at a time through data import and data extract inserts
    IMPORT_BATCH_INSERT = 1000
