Customizing Help on the UI
You can change the default settings of the Help menu in Cloudera Data Visualization. You can customize the links for Documentation and Support on the Site Settings interface.
In Site Settings, under Help Menu you can change the following:
- You can change the Text to display for documentation link from the default Documentation to any other title, for example as Customer Documentation.
- You can change the URL for documentation link from the default https://docs.cloudera.com/data-visualization/cloud/index.html to another URL, such as http://books.mycompany.com.
You can set whether you want to show a webpage link or an email address for Support
contact information.
- You can change the Text to display for Support web page link from the default Cloudera Support Hub and the URL for Support web page link from the default https://my.cloudera.com/support.html.
- You can change the Email address for Support from the default support@cloudera.com to another email, such as support@mycompany.com.
