Features
In CDP Data Visualization, you can enable various features
in the Site Settings menu.
Enabling derived data
As a site administrator, you can enable derived data to perform high-level analysis, such as query stacking, cohort analysis, and back joins.
To enable derived data, follow these steps:
- Click the Gear icon to open the Site Administration menu and select Site Settings.
- Under Features, check the Enable Derived Data option.
Enabling custom styling
As a site administrator, you can enable custom styling to set the appearance of visuals, dashboards, filters, and applications through CSS and JS scripting.
To enable custom styles, follow these steps:
- Under Features, check the Enable Custom Styles option.
Proceed to using custom styles, as described in Adding custom styles to visuals.
Enabling data downloads from URL
To enable data download from a URL, follow these steps:
- Under Features, check the Enable Data Downloads from URL option.
Enabling descendant dashboard information
As a site administrator, you can select to show descendant dashboard information on the Visuals page.
To enable the option, follow these steps:
- Under Features, check the Show Descendant Dashboard information on the Visuals page option.
Enabling visibility of associated dashboards of datasets
- Under Features, check the Enable showing the count of associated dashboards of the datasets option.
Enabling legacy crosstab visual
As a site administrator, you can make the legacy crosstab visual available.
- Under Features, check the Enable legacy crosstab visual option.
Enabling speech detection (Tech Preview)
- Under Features, check the Enable Speech Detection on site (Tech Preview) option.
Enabling creating local user
As a site administrator, you can enable local user creation.
- Under Features, check the Enable Local User Creation option.
Enabling data extracts (Tech Preview)
- Under Features, check the Enable Data Extracts (Tech Preview) option.
Enabling search
As a site administrator, you can enable Data Visualization Search.
To enable the search option, follow these steps:
- Under Features, check the Enable Search option.
- Enable Search in Menu Bar
- Enable Search Visual
