Learn how to set Machine Learning (ML) Runtime as the default engine in Cloudera Data
Science Workbench (CDSW).
- Go to the Cloudera Data Science Workbench web application and log in as a site
administrator.
- On the left sidebar, click Admin.
You will see an array of tabs for all the tasks you can perform as a site
administrator.
Click the Runtime/Engine tab.
Select ML Runtime as the Default
Engine.
The default engine type of the workspace is updated. Now you can
create a Data Visualization application. If you want to use ML Runtime only in selected
projects, you can set it as a project-level engine in the Project
Settings. For more information, see Setting ML Runtime as engine in a CDSW
project.
