Creating a CDSW project with CDV Runtime
Learn how to create a Cloudera Data Science Workbench (CDSW) project with Cloudera Data Visualization (CDV) Runtime as the default runtime.
  1. Click Projects on the left sidebar of CDSW.
  2. Click New Project on the Projects page.
  3. Enter a project name.
  4. Select the visibility of the project.
  5. Under Initial Setup, you can either create a blank project, or select a source for your project files.
  6. Click Create Project.
    The created project uses Cloudera ML Runtimes that are managed in the Runtime Catalog.
After the project is created, you can start creating an application. You can select which runtime edition you want to use for the application. For more information, see Creating Data Visualization application in CDSW.
