Creating a CML project with CDV Runtime
Learn how to create a Cloudera Machine Learning (CML) project with Cloudera Data Visualization (CDV) Runtime as the default runtime.
If you know that your project is going to be running CDV, you can add the Cloudera Data Visualization Runtime when setting up the project.
  1. Click Projects on the left sidebar of Cloudera Machine Learning data service.
  2. Click New Project.
  3. Enter a project name.
  4. Optional: You can add a description for your project.
  5. Optional: You can also select the visibility of the project.
  6. Under Initial Setup, you can either create a blank project, or select a source for your project files.
  7. Set Cloudera Data Visualization Runtime for your project in the Runtime setup section.
    You can use the Basic view to select the Cloudera Data Visualization Runtime and add all of its Standard Edition ML Runtimes for that kernel. In the Advanced view, you can add ML Runtimes based on more detailed Editor, Kernel, Edition, and Version criteria.
  8. Click Create Project.
After the project is created, you can start creating your application. If you added Cloudera Data Visualization Runtime as the only runtime during project set-up, it will be the only available runtime when creating your application. You can select which edition you want to use for the application. For more information, see Creating CDV application in CML.
