Build your draft flow
Begin creating your draft flow by adding components to the canvas and setting them up.
                Add an InvokeHTTP processor to the canvas.
Once configured, this processor will call the Wikipedia API to fetch the latest changes.
                        Drag a
Processor from the Components sidebar to the canvas.
                        In the
                                Search
                            field,
                            filter
                            for InvokeHTTP.
 - Rename the InvokeHTTP processor by changing the Processor Name to Get Recent Wikipedia Changes.
 - Click the Add button.
                        Drag a
                Configure the Get Recent Wikipedia Changes
                    processor.
                Properties
- HTTP URL
 - Enter
                                the
                                following
                                URL:
https://en.wikipedia.org/w/api.php?action=query&list=recentchanges&format=json&rcprop=user%7Ccomment%7Cparsedcomment%7Ctimestamp%7Ctitle%7Csizes%7Ctags
RelationshipsSelect the following relationships:
- Original –Terminate
Failure – Terminate, Retry
Retry – Terminate
No Retry – Terminate
                Click the
                        Apply
                    button.
                Add a ConvertRecord processor to the canvas.
                        Drag a
 - In the Search field, filter for ConvertRecord.
 - Change the Processor Name to Convert JSON to AVRO.
This processor converts the JSON response to AVRO format by using RecordReaders and RecordWriters. It infers the JSON schema starting from the recent changes field.
                        Drag a
                Configure the Convert JSON to AVRO processor.
Properties
- Record Reader
 - Select the JSON_Reader_Recent_Changes controller service you created earlier from the dropdown list.
- Record Writer
 - Select the AvroWriter_Recent_Changes controller service you created earlier from the dropdown list.
Failure - Terminate, Retry
 - Click the Apply button.
                Connect the Get Recent Wikipedia Changes and
                        Convert JSON to AVRO processors by hovering over the
                    lower-right corner of the Get Recent Wikipedia Changes
                    processor, clicking the arrow that appears and dragging it to the
                In the configuration popup, select the Response
                    relationship and click
                    the
                        Add
                    button.
                Add a QueryRecord processor.
                        Drag a
 - In the Search field, search for QueryRecord.
                        Change the processor Name to
Filter Edits. - Click the Add button.
This processor filters out anything except actual page edits. To achieve this, the processor runs a query that selects all FlowFiles (events) of the
edittype. -
                        Drag a
                Configure the Filter Edits processor.
                Properties
- Record Reader
 - Select the AvroReader_Recent_Changes controller service you have created from the dropdown list.
 - Record Writer
 - Select the AvroWriter_Recent_Changes controller service you have created from the dropdown list.
- Failure - Terminate
Original - Terminate
                For the Filter Edits processor you also
                    must
                    add a user-defined property.
                    Click the
Add Property button.
                    - Provide the Name as Filtered edits.
 - Provide the Value as Select * from FLOWFILE where type='edit'.
 - Connect the Convert JSON to AVRO and Filter Edits processors by hovering over the lower-right corner of the Convert JSON to AVRO processor, clicking the arrow that appears and dragging it to the Filter Edits processor.
 - In the configuration pane, select the Success and Failure relationships and click the Add button.
                Add a second QueryRecord processor.
                        Drag a
 - In the Search field, filter for QueryRecord.
 - Change the processor Name to Route on Content Size.
This processor uses two SQL statements to separate edit events that resulted in a longer article from edit events that resulted in a shorter article.
                        Drag a
                Configure the Route on Content Size processor.
                Properties
- Record Reader
 - Record Writer
                For the Route on Content Size processor you also
                    must
                    add two user-defined properties.
- Click the Add Property button.
 - Provide the Name as Added content.
 - Provide the Value as Select * from FLOWFILE where newlen>=oldlen.
 - Click the Add Property button, to create the second property.
 - Provide the Name as Removed content.
 - Provide the Value as Select * from FLOWFILE where newlen<oldlen .
                Connect the Filter Edits and Route on Content
                        Size processors by hovering over the lower-right corner of the
                        Filter Edits processor, clicking the arrow that
                    appears and drawing it to Route on Content Size.
                In the Create Connection pop up, select the Filtered edits relation and click Add.
                Add two
                        MergeRecord
                    processors.
                        Drag a
 - In the Search field, filter for MergeRecord.
 - Change the processor Name to Merge Edit Events.
 - Repeat steps a. to d. to add another identical processor.
These processors are configured to merge at least 100 records into one flowfile to avoid writing lots of small files. The MaxBinAge property is set to 2 minutes, which makes the processors merge records after two minutes even if less than 100 records have arrived.
                        Drag a
                Configure the two Merge Edit Events processors.
Properties
- Record Reader
 - Record Writer
 - Max Bin Age
 - Set to two minutes by providing a value of 2 min.
Failure - Terminate
                Connect the Route on Content Size processor to both of
                    the Merge Edit Events processors.
- For the first Merge Edit Events processor, select Added content value from the Relationships options and click the Add button.
 - For the second Merge Edit Events processor, select the Removed content value from the Relationships option and click the Add button.
                Add two PutFile processors to the canvas.
                        Drag a
 - In the Search field, filter for PutFile.
 - Change the processor Name to Write "Added Content" Events To File.
 - Repeat steps a. to d. to add another identical processor, naming this second PutFile processor Write "Removed Content" Events To File.
These processors write the filtered, routed edit events to two different locations on the local disk. In Cloudera Data Flow, you typically do not write to local disk but replace these processors with processors that resemble your destination system, such as Kafka, Database, or Object Store.
                        Drag a
                Configure the Write "Added Content" Events To File
                    processor.
                Properties:
- Directory
 - Set to /tmp/larger_edits.
 - Maximum File Count
 - Set to 500.
Failure - Terminate
Success - Terminate
                Configure the Write "Removed Content" Events To File
                    processor.
                Properties:
- Directory
 - Set to /tmp/smaller_edits.
 - Set to 500.
Failure - Terminate
Success - Terminate
                Connect the Merge Edit Events processor with the
                        Added content connection to the Write
                        "Added Content" Events To File processor.
                In the Create Connection modal select merged and click the Add button.
                        Removed content connection to the Write
                        "Removed Content" Events To File processor.
